NolimitZ32 wrote: ↑Mon Apr 22, 2019 10:15 am
The most cost effective will definitely be to go with a Z32 trans, they are very strong, there are people running upto 900chp on factory boxes. The work is not that involved and anyone with basic mechanical skills and a good diy guide can do it. I don't know any shops in FL so I cant make a recommendation, what I can recommend is that you search Nico and google for Z32 manual swap guides because there are many. As for parts, the cheapest option would be to find a wrecked manual car or one with a blown engine and strip everything off of it because doing it piecemeal will cost more.
Great information, thanks!
There are many different manual trans that came with the 300zx I believe. Which one is strong like that? Is it the TT manual transmission? I know there is a difference between the NA manual and the TT manual. I also believe there is a different TT manual for the 96+ (The ones made in Japan past 96 I believe had a different transmission too)
Which one can support those numbers you said above?
