KEMP wrote:so, what do you suggest me doing?
it was leaking out of the back like many people have had problems with.
i always torque to 30, loosen, torque to 55, loosen, and then torque to 86-90.
in the correct sequence as stated by the FSM.
the hed is going to a performance machine shop, and will be true. the block was decked before, but the car has not over heated or even came close since that. is there any way the block could be not true?
what do you recomend.
Listen to me folks and listen real good. The #7 and 10 headbolts are tricky because the nissan casting on the head is a bit excessive to fit a standard 10mm hex socket. What's happening to most of you is that the drag on the hex socket causes an inaccurate reading on your torque wrench which subsequently will leave the #7 and #10 headbolts not completely torqued which in turns causes you guys' leaking.
If this doesn't pertain to you and you are sure you've done everything right, then you may want to go back to a composite gasket. I can only go off what you guys post on this forum. I have no idea what you are actually doing, but it's kind of ridiculous that people are having the same problem from cometic's metal h/g.
Dee
