Best Method to launch your 240
ahbongkeo
Car: 95 240sx se
What is the best method to your 240sx? Rpm and etc. ...
S13240
Sorry to say but each car is different and each person has different methods of launching.
Personally though, around 4k rpm feathering clutch. At the drag strip it's around 4k rpm feathering clutch and three-quarters of throttle.
ahbongkeo
Car: 95 240sx se
how bout to keep your car from rolling...do you use heel/toe or the e-brake
S13240
The drag strip was too flat for me to roll so I used neither. :D
Although when I'm on a hill or something I use e-brake, don't want to try braking and revving and depressing clutch all at the same time, too damn stressful on the leg.
240Knightrider
you know you can hold the car while revving and just holding the clutch, you dont even have to rev (unless your getting ready to race). Im sure you know this but by using the break on hills and stuff seems like more work than just holding the clutch.
IlIkEmYz
Car: 06 Z
when im on hills i just use the brake. then if i want to go i just do what i normally do. but if the hill is super steep i just the e brake
maxpower
Car: WRX
pop the clutch at 1.5 k rpm, but you have to be sure it stays at 1.5k and only starts climbing once the transmission is fully engaged. In result you'll have a near-perfect neck-snapping launch.
240Knightrider
I was thinking around 1.5 also because I used to launch at around 2500, but then though maybe I should watch the rpms and see what it goes down to when I pop the clutch. At which it went downt to 1500rpms.
easymmkay240sx
tires, clutch, flywheel, etc. will all change how you launch the car...You just have to feel it out.
k6kicker
Car: 90 300zx(tt) 95 240sx
yeah the 1 and a half grand dump is the best for us lacking an lsd...for that added edge you can bleed a few pounds off the back tires for the race (so what if someone calls you a cheater for it, its not like running slicks)
#RealRiceGSR#
maxpower. please change and update your e-mail address. it is getting invalid hits.
silkk
Car: 94 B13
89 S13
07 S2000
get msd and 2step
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
eh i launch between 4-5k...i have hoosier rear TIRES...heh they're not slicks :rolleyes...SR>KA...bwahaha
s15nc
Car: Baseball, fast cars and women
It also depend on road surface and what not. I was driving around the other day and did about the same launch on two consecutive lights one was a lot slicker surface than the other and my tires squeeled like biotch when I went over the stop line and just kept spinning the other time I had a little cherp when on the line and I was gone.
Altiman94
Car: 1989 Nissan 240SX
I launched at 5k with a near stock, non-lsd ka24e. The track was well prepared. Anything below that, and I would just bog. I had a little wheel spin, but was hitting 2.0's
240SXer
Car: 1995 240sx SE (2jz powered)
I launch my SR at 11psi at 5k on Nitto Drags.. It just depends on the setup of your car. On Kumos I'd spin even if I didnt launch. :)
IlIkEmYz
Car: 06 Z
heel toe works good too
