ArtistikD42 »
https://forums.nicoclub.com/artistikd42-u136272.html
Tue Jan 19, 2010 11:20 pm
i was going to sell it but the guy that was going to purchase my car ended up buying a brand new honda accord so i was like w.e and i only wanted to sale my car because i was about to pick up a e46 m3, but the guy who was going to sell me the m3 needed to trade in the m3 to buy his new mercedes suv. umm for my interior work thanks a lot it was a pita to do but very easy. for the door panels umm remove the little cover where your door handle is and u you will a screw remove it with a phillips. After that you grab your armrest and lift up and it will pop off u might have to use some force. after the armrest is remove you will find two bolts unscrew both of them. now take a flat head around the door panel edge stick it in there and start prying it off they come off fairly easy so should be to hard once you are done you can start adding your fabric . what i did was cut out a triangle that is a little bigger then the cushion on the door panels. after that i started stuffing the top edges of the cushion part with the fabric after the top was done i spray like 2 layers of adheasive spray and laid out the fabric making sure there was no folds and what not i put the little panel with the window part back on and reinstall my door panel back to my car. for the rear seats the nut behind the door handle is not a screw but a bolt so your going to need a torque wrench to unbolt that one. to do your a pillars grab a hold of the top part and yank down it will snap off and just pull it towards you and it should slide out. and to wrap that part should be easy just figure it out its common sense lol
