Best location for a mechanical oil pressure gauge
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I bought a mechanical oil pressure gauge from the local parts store so that I could monitor my oil pressure. The problem I am having is where to mount it so that it isn't in the way. Anybody have any suggestions? I know that one guy was thinking about mouning his in the clock location since his radio had a built in clock but I'd rather not do that because I'd like to keep my clock where it is. Thanks
Matt
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
Pod mounted to the A-Pillar, like where a boost gauge would normally go?
Extra length wires and lines, so you can tuck it under your seat, out of sight, and take it out when you want to check it?
In the place of an air vent for the A/C?
I'm not sure if you want it stealth or not...... Sounds like one to figure out for yourself.... just make sure anything you do can be reversed, or hidden/minimal alterations that aren't likely to be found (ie; Don't screw it down to the dash!)
Skibane
Car: 2000 Q45 AE 110K
Several Q owners have adapted A-pillar gauge pods that were orignially intended for other vehicles in the aftermarket - Should come up in a search...
