Big difference in sound, my butt dyno says its faster, but I know thats not the case, Blake says his car was slower with his injen intake. I have the fujita, and love it.striklybidnis wrote:Any thoughts? Or are they too comparable to see a difference?
Figured this was a good place to start modding my 3.5. Cheap, something I can do myself in little time, noticeable difference in sound (and power?).
Thanks.
Injen sounds great. Its the best of all of them. Deffinitly get the Injen. Its convient that I have one for sale. Shoot me an email if your interested.striklybidnis wrote:Any thoughts? Or are they too comparable to see a difference?
Thanks.
I have the Fujita and I love it. It just roars once it gets to 4k. Got a10whp and 14ft/lbs gain at the wheels on before and after. Check out the dealer locater at http://www.f5air.com you should be able to find one close to you. Or E-bay it...jaimea86 wrote:i have a 3.5 se sedan and i want to get a fujita intake. where can i get that?? :
i just installed mine, my butt dyno says my power gain was over 9000adidas2go wrote:
I swear it was
Nissan discontinued the 3.5 Nismo cat-back. You can still find a few on ebay, or you can go with the 2.5 and get the required part fabricated.RedAlertMitch12 wrote:This is my first post on the forum. I purchased a 2012 3.5 RS Coupe a couple weeks ago and actually ordered the Nismo Cat-back exhaust that Nissan listed in their brochure. As it turns out, the exhaust is not available for the coupe - Nissan's bad. I will be selecting an alternate system (there is some great info available on this forum for exhaust systems) but the purpose for my post concerns the Fujita intakes. Their web page is not very user friendly when it comes to contact information. I would like to touch base with them and find out if anything is available for my application. Those are the two mods that I would like to make initially (exhaust and intake) if I can get some information. The 2011 and 2012 may be similar enough to be used laterally IDK. If you guys have any further information please pass it to me.
Further, I just spoke with the Dealership and will likely be purchasing the Borla exhaust system (if it is available as a cat-back kit). I don't know how beneficial the axle-back kit will be for HP increases. That would likely fit better under an exhaust topic...lol
The 9.36hp gain is most likely the maximum obtained on a dyno by K&N throughout many runs. Their site does not say that it is the average increase, nor does it say it was tested on our exact vehicle, or that the vehicle's other components were stock.RedAlertMitch12 wrote:That's the intake I will likely purchase today: http://www.knfilters.com/search/product ... 69-7062TTK It hasn't been officially cleared for the 2012 on the web site but they say the fitment is the same as the 2011. The HP gain is right at 10 ponies - that's significant (at the wheels)... The Dealership is installing my Borla axle back system this morning and I'm hoping for a credible increase in power. When its all done I will report the results.
I really like the way the K&N isolates the filter from the heat of the engine and still allows the factory cold air duct to plug into the side. The system actually looks factory with a performance twist..IMO
True, but I've never had any problems with knockoff intakes on my two last cars so I feel I don't have much to worry about.funkee wrote:mattyfo0z: I wouldn't bother with an intake. But if I ever did, I would certainly go with a reputable brand. The intake is one of the most sensitive areas of the car. If any part of the intake fails you might suck in some nasty s*** into your engine that could cause very expensive, possibly irreparable damage.
That's why I've been holding off on getting an intake myself. My engine is under warranty. If Nissan's intake fails, I'm in good shape. If my ebay intake fails, and I suck in some sand, gravel, bugs, water, etc - there goes my engine and a p0rn load of money. If the only gain from an intake is sound (and there aren't any worthwhile gains in hp or mpg) then it's not worth the money and the risk.
The only intake I have ever seriously considered was K&N's. They have a guarantee that if the dealership refuses to repair your engine under warranty and blames the intake, they will duke it out for you. That's still a lengthy process, but it's more of a promise than some ebay seller will give you. Check it out here: http://www.knfilters.com/warranty.htm
I don't know if it's like this everywhere here in CA, but I've taken a handful of cars to get smogged before and not once has the shop lifted up the car to do a visual inspection. They do pop the hood and check out your setup, though.. so an intake or header with no CARB stamp will probably fail you on the visual part. I myself won't be too worried when it comes time to take my car to get smogged with the RL y-pipe + full exhaust. I'll probably take off my intake just because it only takes about 15 minutes and I'd rather be safe than sorry with having to pay again or get my car resmogged.The Borla axle-back will sound very nice. But the most limiting factor are the catalytic converters. Unfortunately, here in Cali, you can't even delete one of the three and pass a "visual" inspection.
