best injectors/size to get
astro
hi,
im running a ca18det it has about 70 thousand kms on it,
secret sports 1.2mm head gasketgredddy fmics15 turbo, w/ hks actuatorblitz boost controllwalbro 255l pump3" downpipe, and exhaust
im wondering what kinda injectors i should get, what size is good and anyone know where i could purchase some online or localy in canada
thanks alot
paul_s13
Some GTR/Pulsar GTiR 440's should go well with that spec, you probably won't need anymore because from what I can se your running the standard compression ratio.
themadscientist
444cc isn't much of a step up from 370cc. The S15 came stock with 480cc ones so you would already be in the hole. If you have some good GT-R squirts laying around by all means throw them in but if you are going in search of injectors I would get some 550cc shooters if I were you.
Spectre23
Car: S13 CA, 2013 STi, Tony Kart
Or you could run 444's with higher fuel pressure. My ECU was tuned for 444's running at 53 psi. Basically that is like having a 525cc injector I think. Now if the stupid dealer could just get my injector o-rings in...
