...and if you did, how much did it cost?ridinwitha35 wrote:Same car, same issues....though one thing you should check is your sway bar endlinks & bushings. Also get an alignment & check your tire wear. I would check those before buying new struts, especially since you just bought the car.
PS: I just bought my car too, and had the exact same feelings as you regarding the ride quality. I was going to add a front strut tower brace (fstb) and rear anti-sway bar (rsb) but after going to the dealer, they discovered my endlinks were bad, alignment was off, and uneven tire wear though I still had some tread left. So I say check those first then look into upgrades.
How much was yours?parksmopar wrote:Hey guys,
Its like this, I own a 2003 I35 and was having the same issue. I called Cattman Performance and talked to Brain Cattman. He hooked me up with a set of struts, springs, boots, and bump stops and a rear sway bar for a good price.
The struts were KYB and the springs were from a company called Progressive.. *shrug* I do that I LOVE the way my car feels and drives right now. I have had them on for about 3 weeks now and its a whole different ballgame. You will need to get an alignment done afterwards but ya'll might want to check in with Cattman.
He doesn't let you order through the website so you have to call him. He is Very knowledgable about our cars and nice to boot.
Hope this helps.
How are GR2's?DblOsmith wrote:Has anyone used KYB GR2's on their I35? How are they? Soft? Firm? They were fine on my Celica, but I don't know how they'd be on a car that weighs 1000 lbs more.
johnnyd6404 wrote:The front is simple open the hood and use a flat head screwdriver to turn the selector its located on top of the shaft. The rear is a little more trickey cuz its in a tight spot but the same process all you need is a screw driver. I'll post some pics tomorow for ya.
