best flywheel?
DSble315
Car: 1990 300zx na
im working on my 5 speed swap and its cool time to get my flywheel. any sugeestions on what ones have worked for you? my cars an na but i need a tt flywheel. just want to get a quality one not some ebay crap.
XX7R
Car: 1990 300ZX TT
So your car's an Na with a TT motor? Anyways specialty z is always good https://specialtyz.com/shop/sz-flywheel-vg30de-tt.html
DSble315
Car: 1990 300zx na
I was looking at them yesterday actually thought theirs looked good. And no its an na but the 5 speed im putting in is from a turbo. Thanks for the suggestion :biggrin:
XX7R
Car: 1990 300ZX TT
I thought that the bellhousings on the tt and na trannies are different?
nissanfreak12
Car: 92 300zx 2+2 TT
The bellhousing will bolt up the same, the TT is just a little larger. As long as he uses a TT flywheel and clutch he will be fine. Everything else will bolt up just fine including the driveshaft, as long as ts a 5 speed. Your speedometer will be off if you still have the TT speed sensor in it.
DSble315
Car: 1990 300zx na
Yeah exactly, but i didnt know that about the speed sensor. Does that mean i need an na one? Are they the same size?
nissanfreak12
Concept Z Performance, you can buy just the gear, its like $26 or close to it. If you keep the TT gear, it will just make your speed 5-8 mph faster depending how fast you are going. Very simple to replace, pull SS out the gear is held on by a snap ring. After taking the ring off, slide the new one on. Put SS back in.
You are going to have to lower the trans just enough to slide the SS between the body and the exhaust. Is not that hard, I have the TT sensor gear in mine with a NA rear end, I have just dealt with for now. Isn't too bad.
DSble315
Car: 1990 300zx na
Ok man thanks, I didnt know that. I assume i cant just use the one from the auto transmission? and itl be easy for me since id put it in the 5 spd before it goes on the car
300ZXttZMAN
SZ flywheel is amazing. You can't go wrong with anything from SZ IMHO.
DSble315
Car: 1990 300zx na
Yeah the SZ one looked like it would be the best option, but since money is tough at 17 i just wanted to make sure that would be a good purchase!
nissanfreak12
DSble315 wrote:Ok man thanks, I didnt know that. I assume i cant just use the one from the auto transmission? and itl be easy for me since id put it in the 5 spd before it goes on the car
Manual SS are the same except the Gear at the end. Auto SS are much shorter, will not work period, not even the gear.
DSble315
Car: 1990 300zx na
Ok thanks, guess i need the new one.
