best diy way to pull/roll fenders?
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
what it says in topic... just wondering becuz im going to need to correct my camber soon but my fat wheels wont clear as of right now unless i pull/roll my fenders
Axel Grungy
Car: 2001 G20 5spd
baseball bat
spanishricer
Car: '95 240SX & '03 M45
I used a baseball bat on my rear fenders when my tires wouldn't clear them at stock height. No rubbing at all now.
But looking at the pic in your sig, it seems like you would have plenty of clearance. Even with camber corrected...
nismofly
Car: 89 Nissan 240SX Hatch
so i take it the camber in that picture isnt correct? i had the same thought
how bout a fender roller/puller...i dont know if its the same thing or two seperate things ive never used or seen one, just heard about it on here a lot
sixxdeuce
Car: 93 rx7, G35coupe 6mt
rent/borrow/buy the eastwood fender roller, it rolls and pulls fenders very nicely.
Eastwood put up some of my pics using it on their site:http://www.eastwood.com/text/c...r.htm
spanishricer
sixxdeuce wrote:rent/borrow/buy the eastwood fender roller, it rolls and pulls fenders very nicely.
Did the fender roller also help you to "pull" the fenders, or did you use another method?
cyrus240sx
yeah i have nothing to adjust my camber in the rear right now so i have a good amount of negative camber because i dropped it, but when i give it say -.5 or something around that range then ill have issues....on another note... what kinda wheels you got on your s14 spanishricer? from the pic all i can see is a lip and they look nice and fat
Modified by cyrus240sx at 11:00 PM 5/22/2005
sixxdeuce
It was the only tool used to pull them, just apply heat to the fender, slice the paint on the underside and slowly work the metal out.
spanishricer
cyrus240sx wrote:on another note... what kinda wheels you got on your s14 spanishricer? from the pic all i can see is a lip and they look nice and fatModified by cyrus240sx at 11:00 PM 5/22/2005
They're Enkei PK-6's. Pretty much same setup as you, just a size bigger. 18x8.5 +24 up front with 245/40/18 and 18x9.5 +25 with 275/35/18 in the rear. The rear tires rubbed on dips and bumps while still at stock height, so I just took the Louisville Slugger to it
spanishricer
sixxdeuce wrote:It was the only tool used to pull them, just apply heat to the fender, slice the paint on the underside and slowly work the metal out.
When you say slice the paint, do you mean cut grooves into the inner lip that's rolled flat? Sorry, I'm just trying to get a mental image of the process since I'm definately going to have to pull my fenders before I can drop my car.
sixxdeuce
yeah, you slice a groove in the paint on the part you cant normally see. Also, 9.5" width with +24 offset should tuck under compression with no issues, its probably those ginormous tires you have in back, or your camber is messed up.
spanishricer
sixxdeuce wrote:yeah, you slice a groove in the paint on the part you cant normally see. Also, 9.5" width with +24 offset should tuck under compression with no issues, its probably those ginormous tires you have in back, or your camber is messed up.
Yeah, it's the tires...they're mammoth
