Best Dampers?
Streets_of_Fire
What do you guys think? KYB AGX's or Tokico D-Spec?
nismofly
Car: 89 Nissan 240SX Hatch
if you get stock springs like your intention was in your other thread, go with a set of KYB GR-2's, theyre a stock replacement damper that will be matched fairly well for the stock springs
boznuttz
Car: MS13
i couldnt bash on koni yellows if i TRIED
Streets_of_Fire
dayu, too many choices, but im trying to narrow it down between tokico and kyb, i havent read much on konis
boznuttz
Car: MS13
do some research on the koni yellows. if you have the money for them... it really is the best strut ive used so far as well compared to the gr2s, agx, and tokiko blues. no competition whatsoever. simply amazing.
Modified by boznuttz at 1:05 PM 11/7/2006
C-Kwik
According to Eibach and the testing they've done on their shock dyno, the Koni's are one of the best shocks out on the market.
boznuttz
Car: MS13
my car knows, lol.
94_240sx
Car: 94_240SX
Can you adjust Koni yellows just like AGX? I'm asking you this because I've heard that it's hard to adjust for some of adjustable shocks out there. I wonder Koni yellow is one of them. What I heard is you have to remove the shocks to adjust. AGX is very easy since knobs are on the body.
C-Kwik
I believe all the Koni Sports use top adjustments.
What kind of car is this going on?
nismofly
i believe the rear koni's you need to pull the wheel off to adjust them
94_240sx
Car: 94_240SX
nismofly wrote:i believe the rear koni's you need to pull the wheel off to adjust them
I think that was it. I heard people complaining about not being easy to adjust.
calico
need to do more than just take the wheels off... you have to take the shocks off on the rear to adjust them
http://koni.com/_cars/frame.html
click on "general info" on the left and then "adjustment" under the Installation manuals section and it'll tell you how to adjust. look at the adjustment for the 8040 series, it's the same for S13 and S14
94_240sx
Car: 94_240SX
calico wrote:need to do more than just take the wheels off... you have to take the shocks off on the rear to adjust them
calico,Thanks for the info. I think people should know about this before they spend money on it. I would definitely buy something easy to adjust...
Streets_of_Fire
this is for an s14, and yes i will stay away from konis! i was leaning towards tokico, which manufacturer makes the most OEm supply ? (especially for OEM sports cars) ?
