DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Fri Dec 02, 2005 10:23 am
ACT and Centerforce are both very good clutches. there are few finer clutches that could be recommended in a reasonable price range. Centerforce clutches are very nice, dont worry
i wish i had your suspension... instead of nothing...
anywho, lightwheel flywheels have a lower moment of inertia than the stock flywheels. engineers do all they can to move as much weight to the outside as possible, but there is only so much you can do.
lower moment of intertia means it will accelerate (the flywheel) much easier, but it will take more work to keep it going at a constant velocity. the tendency of the flywheel is to drop revs, and quickly.
you'll gain revs and lose revs very easily. also ive heard there is a small amount of low end loss, but an obvious top end gain.
more stalling when feathering the clutch and such, maybe rev matching, double clutching, or heel and toeing might be affected, but you will obviously learn to live with the change and you wont have it any other way....
if you have 300 bones ebay has your fidanza, do it up
