Best cheap rotor/pad combo
AZ89two4Tsx
I have these brand new rebuilt G50 front calipers waiting to be put on my sil40. I need rotors and pads, and was wondering what to go with. They don't need to be slotted or anything just up to oem spec.
So what should I go with? Is there any aftermarket brands that you've had a good experience with? I mean, I'm just looking for something that is the best bang for the buck. I don't need ceramic pads and fancy rotors, but the most important thing is they don't squeek/grind. Dealer stuff is expensive as usual, but if there's nothing better for cheaper, I guess I'll "brake" down and get that, lol, I'm a nerd.
Any suggestions are welcome.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
OEM for both, or Brembo blanks for the rotors.
http://www.infinitipartsusa.com
http://www.tirerack.com
AZ89two4Tsx
$90 per rotor? Awesome.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What if you get crappy Autozone rotors and good Hawk pads?
Rex
Car: None
Unfortunately, you have to pick either cheap or good ... and usually with a Q45, there's not a cheap option.
One of the main reason so many S-chassis guys go with the Z32 over the Q45, is replacement rotor costs (high) and options (low).
You've got less to worry about from a mass/warping standpoint, but most Q45 rotors are made with the Q's weight in mind.
NightRiderQ45
Car: 1998 Infiniti Q45
Paul Wall wrote:What if you get crappy Autozone rotors and good Hawk pads?
How do you know if they are crappy? Have you personally used them before?
Infinitiguy19
Sadly yes. The only thing with cheap rotors is that they warp faster than any of the more expencive ones.
This might help with preventing brake rotor warping: zerothread?id=98539
AZ89two4Tsx
W/E. I cheaped out. I bought the rotors/pads at Checker/O'Rielly.The pads are a semi-metallic and made by Wagner.
I let you guys know how they are once I get them on. Hopefully they aren't that bad.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AZ89two4Tsx wrote:W/E. I cheaped out. I bought the rotors/pads at Checker/O'Rielly.The pads are a semi-metallic and made by Wagner.
Reading the previous posts will save you a lot of money!
adrianfromthecastle
Car: 1992 Nissan 240sx
Hawk pads FTW!
I'm in the market for new rotors though. I think i might just go with some Brembo blanks.
Rex
Car: None
Unless I've missed some information, he's using Q45 brakes on an S13, it's several hundred pounds lighter. He's very unlikely to see any warping, unless he tracks the every living crap out of the car.
AZ89two4Tsx
Ok, the brakes are almost done. I'll post pics soon.
The biggest hold up I had with these is finding the mounting bolts for the calipers. THEY ARE A b****. It's 11mm fine thread with a big shoulder, super special. They're available NOWHERE but the dealer (found out the hard way) and at the dealer, they were back ordered for weeks. So I had to go to the junkyard and get them.
Word of advice to you Q guys. If you're buying/selling Q brakes, include the mounting bolts. J30 bolts will work too.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
On the Q we're pretty picky about going OEM parts, but on a smaller lighter car I'd say things are different. BTW, I think it's the same brakes on a J.
AZ89two4Tsx
Ok. I finished them.
The pedal seems a little mushy. Not too bad, I can definitely feel that they're better. Should I think about upgrading the master cyl/booster? I kinda chose the Q brakes so I wouldn't have to.
Any precautions I should take "braking" them in? lol this is my first car.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You must bed the brakes correctly. Read the instructions at Brembo.
Surely you are using the G50 MC?
AlabamaDan
1998 Infiniti QX4
I don't know what the 240 Master Cylinder is like, but I would expect the G50/Q45 one to be heavier. If you're using the G50 calipers, I'd use the G50 master cyl. It's small in terms of space and should be better. I've heard the ones off the 90 models are better - Tokiko.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
well the Q45 has a 1inch bore, I dont recall what the 240 has but I believe its either a 15/16 or a 7/8... Which means you're within about .1" or so.. Not really significant IMO..
I would bleed the brakes really good, be sure to bleed the MC first, then do all 4 corners!
AZ89two4Tsx
Yeah, we bled the fronts just so we could get it off stands and take it around the block. We'll bleed the hell out of it today and then do some hard stops to bed them. I'm sure that'll help quite a bit. Hopefully, it'll be enough.
I don't really want to have to change the master cylinder.
elwesso
2007 BMW M Coupe
Well if your car is a non ABS car it wont do any good because all G50 MC's are for ABS cars.
AZ89two4Tsx
Good, kinda. I don't have abs.
AlabamaDan
1998 Infiniti QX4
I'm not sure if it's 100% the best way, but I always get up to about 20-25MPH then press the brakes hard a few times to bed the brakes. I also do the same in reverse, only not as fast. It's been working for me so far.
