Clipsed wrote:Memphis is pretty good, Question is how much did he want for the set-up? My recommendation would be an Eclipse headunit. And if you like the features and can afford the close to $500 headunit, it is one of the best as it has an 8volt preout for your amps, meaning less gain on your amps, and less strain on em. But for that price you also come navigation ready on that headunit.
Speakers, you could get some nice MB Quart components up front, and some decent 6 1/2's for rear fill.
As for your low end, you could also go with some JL 12W6's or 10W6's, your call on which size or one or two, and get some JL amps. This should put you in that price range, and give you a really clean crisp high and mid and a hard hitting clean low end.
Note: Not all Eclipse head units have 8V preamp outputs, and not all amps can handle 8V preamp inputs. This is one reason you want to deal with a reputable shop. They'll know to check such things. I totally agree that the stronger the signal, the better the noise rejection. But balanced lines are definitely preferred.
I like to use the stock speakers for rear fill. Typically, if you're running the rears as "fill only", you'll be send a lower level (quieter than then fronts). You could use the amp in the head unit for this. The JL Audio 5 channel actually has 100Wx2 (front), 25Wx2 (rear), and 250Wx1 (sub) for facilitate this thinking. In competition systems, a bandpass xover is used to limit the frequencies between 1k & 7kHz. But this is getting really picky.
For the fronts, RainBow, Quarts, Focal, Dynaudio are all good. If you need less expensive, Infinity's are good.
For subs, select the sub based on the type of music you listen to. Ported boxes tend to be more "slammin'" (rock, rap) while sealed boxes tend to be more controlled (jazz, classical). And not all subs work well within all boxes. The box must be matched to the sub. These are generalizations and there will be exceptions. I like Boston, Alumapro, Dynaudio, JL but nothing bigger than 10" and I prefer 8" subs (although I must admit to have a 12" Dynaudio in my basement but that's a special case). BTW, the quality of today's subs are such that a single good quality 10" in the right box can out pound a pair of poor quality subs in an off-the-shelf box. And lastly, I've never been a fan of Kicker subs but I haven't listened to them is a few years.
