Bah to repinning... Im running 248 / 232 with a virgin exhaust cam, with no new holes punched
. I was running 240/248's but thought I would give a 248/232 a try so I put the exhaust cam on the intake side, and swapped in the stock 232.
Impressions: Well the 232-232 has about the most lowend of all the setups IIRC, its just that with a 232 intake it gets choked severely at the upper ranges. Sorry I cant rem specifics as its been 2yrs or so.
The s13 cams or 240-248 gained me a decent amount of upper and mid. Russ said he got 9rwhp from 5k+. I dont know what I got as I drive an auto and probably gained 2 rwhp hehe. Um for me the power was felt nicely at 4.5k+ with the cams and my mods... Another thing to note with a shorter burn time of the 248 the exhaust noise is increased over the 232.
Um 248/232 Is what I currently run, and have been for the past 2 or so weeks. Basically take the 248 exhaust cam, and while the car is at tdc, put it in so that the first lobe set face out, like the stock intake cam you need to pull does. To be specific rotate it and the sprocket CCW 4 teeth... If you are really interested in it I basically wrote out a step by step to someone on FA, so I could post that link... I like this setup, I didnt notice any real loss, but mabey a miniscule amount up top. Mid range is better and the power comes on at 4k vs 4.5k. Fuel economy increased slightly, and exhaust noise wile holding a steady pace at highway speeds is greatly reduced.
248/240: I may give this a try in the next week or two when I get bored. The reason why... I havent heard anyone try it yet and it should remake my engine legal for my class (gotta find out but more legal then now) Should push the upper range up more and drop the mid / low slightly. That is, from my 248/232 setup. It should offer more mid / low then the 240-248. Funny thing is that I will need to rotate this cam as well to work in the exhaust side. So Ill be running a stock set of s13 cams unpinned but swapped from each other..... Good times, miscounting and nearly killing my engine swapping the exhaust cam over (my best friend cant count, moral: always dbl check for yourself) wasnt enought so Ill give it a go with the 240
248/248: um gimmie a exhaust cam and Ill tell you. What I do know is that it produces the most peak hp of any stock cam combination. It gains about 6rwhp at 6k - 6.5k from the 248-232, but the 248/232 gaines 4 hp over the 248/248 from 2k-5k (another member of another board dyno'd and posted his results). The 248/248 is a better highway cam setup (drag), while the 248/232 (or 240/248 for that matter and possibly 248/240) is a better around town cam (soloII), where mid range is used and is fun. Also the 248-248 is the loudest setup, and has the least fuel economy.
That help any?
Oh and dennis posted in that post I talk of on FA.com.... Hes not running a repin either, but a rotated exhaust cam on the intake side, and a stock exhaust cam... 248/248
