best bang for the buck rods/pistons????
TylerS13
Car: 1990 240sx
hey guys im going to be going ka-t soon and i was wondering what is the best rod/piston combo for this set up i've seen the eagle rods and pistons for sale but they are a little out of my price range does anyone know of a cheaper set up and what website i can find them on?
moneymike
Car: 1991 nissan d21 hardbody
you get what you pay for
eagle rods are just about the cheapest rods you can find
i just got my block back with cp pistons and crower rods cost 1300 for em
TylerS13
Car: 1990 240sx
ahh alright i didnt know if there was anything around the same quality for a little cheaper. whats the best website to buy 240 parts other than enjuku?
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
TylerS13 wrote:ahh alright i didnt know if there was anything around the same quality for a little cheaper. whats the best website to buy 240 parts other than enjuku?
I like these pistons for the money. Good to 700+whp and I like the 8.8-1. You can get the ams sportsman rods from this same sight but you can save $100 getting the eagles from importDPS.
AMSperfomance- arais pistons $500
http://www.amsperformance.com/cart/Niss ... parts.html
importdps- eagle rods $300
http://www.importdpsonline.com/eagle/ea ... 54683.aspx
Thats $800 for both.
Then of course you will need about $500 for , headstuds, HG, gasket kit, timing chain kit, bearings, etc..
SiDwAyZ240
Car: 95' SR Slayer, '02 LT Tahoe, '03 Chev Express is the DD
Unless your set on changing your compression, I believe that the stock rods are the weakness in the KA. You could just get some forged rods and rock the stock pistons. I think you would have to be pumping major boost to melt a piston.
Doya
Car: '95 240sx KA-T
I'm using CP Pistons and Eagle Rods. http://cgi.ebay.com/ebaymotors/CP-Pisto ... ccessories
JDizzle
Car: 1995 Nissan 240SX
Best place to find pistons and rods for a good price is on ebay. They have the CP Piston/Eagle rod or Wiseco/Eagle rod combo for cheap. Nothing wrong with Wiseco but I wouldn't run anything other than CP Pistons in my vehicle. I used to work at a shop that was direct with CP, we never had any issues with their product.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
100% positive feedback!
They have a ton of different combo's too! Eagle,Pauter,Crower etc.... JE, CP, Wiseco!
http://cgi.ebay.com/ebaymotors/Wiseco-P ... ccessories
WDRacing
SiDwAyZ240 wrote:Unless your set on changing your compression, I believe that the stock rods are the weakness in the KA. You could just get some forged rods and rock the stock pistons. I think you would have to be pumping major boost to melt a piston.
If you can tune out detonation, the stock pistons will definitely outlast the stock rods. The rods bend at or just before 500 ft lbs of torque. IMHO, unless you're going for more then 450 whp you can get away with just doing a factory rebuild. New oil/water pumps, gaskets, bearings...generally clean up the entire motor. Add boost, done. The reasons a KA fails are mostly knock or issues related to a part failure like the oil pump or you overheat/undercool etc.
BUT, if you do decide to change the rods you may as well change the pistons. Then you'll have to have the entire rotating assembly balanced.
