Best bang for buck when lowering a 2008 Altima Coupe SE
All things Altima Coupe.
disfunctions
Car: 2008 Nissan Altima Coupe 3.5 SE CVT
What is the best bang for your buck when it comes to lowering my car?
Coilovers vs spings?
what gives the biggest drop?
any thoughts?
also do you guys think wheel spacers/wheel adapters are a good buy?
Thank you everyone!
SanoSuKe
Coilovers for sure. If you get springs, you'll buy it for $180+ then pay another $200 for someone to install it. And you wont even be impressed with that 1.5 inch drop. I always recommend getting coils so you can get a lower drop and be able to adjust it when it's winter time or something.
Wheel spacers are okay if they're not too big, I think 20mm is the biggest I'd go. If you need them use them, if you don't then stay away from it.
VTMike24
Car: 2008 Altima 3.5 SE 6spd
It really depends how much you want your car lowered, how much you want to spend, and how important ride quality is. Below is a quick summary. The link at the bottom has more info.
Springs lower your car about 1.5 in, cost between $200-$250 and "typically" give you the best ride quality. May require a camber kit depending on setup. I don't have one.
Image H&R
Image Tein
Coilovers give you a drop around 3 in and cost between $700-$1000. Coilovers are "typically" a rougher ride than springs, but most come with adjustable damping. With a bigger drop comes more camber and higher likelihood of needing a camber kit.
Image Tein Street Advance
Image BC
Air ride obviously can dump your car, but costs $2000+ depending on the setup. I don't have any experience with ride quality of air ride setups.
I tried to get pictures with stock wheels to provide a decent comparison. You can always get bigger wheels to further reduce/eliminate fender gaps.
coilover-lowering-spring-options-t559823.html
disfunctions
thank you for the advice! it was exactly what i was looking for!!
