WDRacing wrote:If you can do any custom work, then you'll save a ton of money. The stock piping on the 300ZX is extremely restrictive. So redoing all of that will be a bonus, I don't think you'll need a dual MAF, not sure here but the 300ZX MAF will go past 500whp when used on a 240.
The problem is the engine runs a risk by asking the MAF to max out.
Plus you will double your effective intake volume capacity by simply going to a dual MAF setup.
WDRacing wrote:If your upgrading things as a whole package, new mani's and turbo's is the place to start. I'd use a set of 2530's. They are a very common swap for the RB26. Quick spool without sacrificing flow.
At 3-4k anything that is GT and involves new manifolds on the Z32 are out of the question.
I know for a fact two S15 turbos can be had for cheap in new condition if ball bearing is a must.
WDRacing wrote:But like the other guys said, you'll need lots of fuel and the turbo's and mani's are very expensive. You could use the stock mani I suppose, but even the turbo's are expensive.
Fuel injectors are extremely expensive and top feed rails won't exactly make it any cheaper either.
Stock mani's can be ported to some benefit.
WDRacing wrote:The stock intercoolers suck, so you can fab your own fmic piping and buy a IC cheap on ebay. Or use a water sprayer on your stockers which help quite a bit.
You won't find a correctly tanked core on Ebay, the Z32 needs two inlets, and two outlets. Then the piping is an absolute nightmare to make. People also make more power on the sidemounts for the level you are seeking.
Increase airflow to your stockers and rig water injection like Brian said. Good luck finding room for all this crap though.
There is very little room the Z32's engine bay for accessory pumps and resevoirs. Plus you have a problem with the intercoolers supporting the FLOW moreso on Z32's than the heat.
