quiksilvia wrote:im guessing he means that u should rewire to make sure that the wires are good and wont fail when u need fuel the most. but if u just have a walbro, u dont need to rewire anything
WRONG. And on both counts.
The wiring to the fuel pump is too small to support a lot of horsepower, theoretically, it can cause you to lean out if not enough power is making it to the fuel pump. I'll admit, it probably won't happen, but I'd rather make certain it doesn't. All you need to do is go to radio shack, get a 12V ignition relay and run a direct 12v (not too small of wiring, but not huge of course) all the way back to the fuel pump off the battery or some other constant 12v source. Then run a new ground somewhere on the chassis, and you use the positive wire that used to be for the fuel pump, as the ignition signal, then run power off the relay to the pump.
So basically, instead of your stock wiring powering the pump, you use it for the remote relay, and you run a dedicated power line to your fuel pump.
The guy who told me about it does wiring and high HP aftermarket tuning for a very well respected shop, so I believe him, and it is such a simple idea.
And you should rewire it, REGARDLESS of what pump you have if you are going for higher HP numbers. None of this "you don't need to rewire if you have a walbro" crap. If the line fails, your motor is going to be the one hurting, regardless of what fuel pump it has in the tank.
