I wonder whatever happend to the OP. I wonder if he found his 4x6's or found a way to get 6.5's?
Nismo775 wrote:jl is the best and for those who say otherwise either dont have the money, or dont like quality.
That's true they are the best...Until you hear better, which when getting into the upper echelon, differentiating between drivers (subwoofer drivers) becomes increasingly more subjective and application dependent than objectively measurable...much less debateable.
Nismo775 wrote:the W7 is a very great sub. the cleanest sub that i have ever heard.
Well there ya go. It's the best sub you've ever heard because you've not heard better. simple.
It's like saying the 240 is the best car anyone's every driven...until they drive a better car.
*edit*I will explain "application dependent" a bit more. A speaker driver is just a tool; a means of reproducing sound from an electronic signal. For any job, you really need to use the right tool for that job. When used appropriately, any quality tool can do good job, when used inappropriately, even the best tool will have poor performance.
So, a W7, used in the correct size enclosure and for an appropriate goal will work very well. When used in the wrong enclosure and/or for the wrong purpose (hence wrong application) could easily be bested by a driver 1/4 it's price when designed for that same application.
When it becomes subjective is when two tools are used/designed for the same application, for example, Porter Cable vs. DeWalt or whatever subwoofers you want to go toe-to-toe.
Modified by Looneybomber at 12:54 PM 5/16/2009
