Well, the guys at NPORA seem to like me more than here, but thanks for hearing me out.
I wouldn't give up so easily, though. I think that H190 kit in the video might actually fit the H233B. A cross-ref on the bearing cages and bearings suggests the axle shaft mounting patterns may be identical. (I can go into more detail about this.) The bearing cage heights are probably different, though, which would require changing the lengths of the stand-offs on the bracket.
The WD21 setup is still a lot easier, but this other approach is far easier than the axle swap I suggested earlier and better to getting to your goal (of course, that suggestion was based on going to a big-brake setup, not just a simple conversion). Customization is the nature of the beast here, though. I would think that with the right design and measurements, a local waterjet/laserjet shop and machine shop could build those custom brackets for a very affordable price...and with enough research, you wouldn't be limited to Isuzu parts. But it's one of those projects that could have a lot of back-and-forth to get the right solution...a beater car sure makes it easier to cope with that.
Just to clarify some other things:
--Yes, you would have a lot of difficulty sourcing Patrol parts here. Patrols are to Nissan what Land Cruisers are to Toyota. A shame we never got them here. The newer Patrols are actually sold here under the Infiniti line, but like the Pathfinder, the newer model is hardly what its predecessor was (at least in terms of off-roading). Though, funny, I've been toying with the idea of getting the R52 for the wife. A new Land Cruiser is completely out of the question, given that it starts at $84K. Jeebus...
--About the WD21 axle...you only need the axle
shafts, not the entire axle. The axle itself won't swap to an R50...similar, but very different. However, the internals are similar, but you just need the parts pertaining to brakes, which are all found on the axle shafts (you'd also want to get the parking brake cables, which usually get cut by the lazy JY removers).
--Glad the chrome shop could confirm the resistance to heat. Guess it makes sense...I've seen other heat-prone items chromed before (alternators, valve covers, etc.). Though...if aesthetics matter, you may need to get creative on how to keep chrome drums shiny...removing the wheel will get old, fast.
--Those Centric drums seem interesting; curious to know how well they last. I do what Fueler described (rattle can it), and they last me a year or so, which is fine for me...but I also rock stock wheels. Another option is brake dust shields, which you can find at Summit:
http://www.summitracing.com/search/part ... -of-lugs/6. Not nearly as elegant as disc brakes, of course, but at least it hides the drum.
On a side note...I now have all the parts necessary for the WD21 conversion (minus any new replacement stuff). I started disassembling things last night, but I'll need to find a shop to press things off at this point to continue. I have no reason to think it won't work.
