PROJECTRB240SX »
https://forums.nicoclub.com/projectrb240sx-u7958.html
Tue Sep 23, 2003 7:06 pm
FOR 15-20 PSI, RB20DET:
GET FORGED STANDARD PISTONS (OVERBORE IF WALLS ARE BAD)TAKE YOUR RODS AND HAVE THEM SHOT PEEN'DGET GOOD WRISTPINS AND PISTON RINGSDON'T USE A THICKER GASKET JUST GET A COPPER REPLACEMENTUPGRADE YOUR INJECTORS TO A MINIMUM OF 400CCPORT MATCH THE HEADCHANGE THE CAM TO ALITTLE LONGER DURATIONCHANGE/UPGRADE ALL GASKETS/SEALS/AND SILICONE SEALSUPGRADE THE TIMING BELTUPGRADE ACCESSORY BELTSALSO CHANGE TO STUDS FOR ALL MAIN BOLTS
THE ONLY THING WITH INTERNALS ARE PISTONS NEED TO BE PRESSED ONTO THE RODS WITH THE WRIST PINS. AND YOU MAY NEED TO HONE THE WALLS OF THE CYLINDER IF THERE IS SCUFFING/GROOVING. OHH AND MAKE SURE AFTER ANY INTERNAL CHANGES YOU GET THE MOTOR BLUEPRINTED AND BALANCED, IT WILL PROLONG THE LIFE OF THE MOTOR, INCREASE POWER, AND KEEP THE ENGINE RUNNING SMOOTH.
