Beshoff Project: Blown FX35
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
Brian@BeshoffInfiniti
Today we start with this:
and add pressure to spice things up
Story to follow
Modified by Brian@BeshoffInfiniti at 6:51 PM 11/30/2009
Off with the old belts and pulleys
Clean pallet to work with
New belts waiting to go to work...
Pretty billet and anodized aluminum pulley. Very tasty
The fuel pressure regulator gets a nice looking aluminum spacer that is tapped to feed the 7th injector
Valve cover breather equalization tubing is rerouted to clear the compressor belt
And the new snazzy intake plenum base is installed
The bad boy sits waiting, ready for work
Sorry for the mystery: The project car is a customers 2008 FX35AWD with the VQ35DE engine. The project involves a Stillen Stage 2 supercharger kit and Stillen stainless steel cat back system.
The supercharger is a roots type running 6 lbs boost. Stillen dyno test results show a 110 hp increase at rear wheels. (The 2008 FX35 was factory rated at 275 hp) The install is 50-state CARB legal.
This project has been a lot of fun- fit and finish has been perfect.
A nice picture of the massive heat exchanger directly beneath the rotary vanes that will cool the pressurized intake charge
fitting the beast, it's a tight but perfect fit
A picture of the 7th injector that will feed the beast when it's angry
Modified by Brian@BeshoffInfiniti at 6:32 PM 11/25/2009
Modified by Brian@BeshoffInfiniti at 6:34 PM 11/25/2009
Modified by Brian@BeshoffInfiniti at 8:06 PM 11/25/2009
psmwrx
ive driven a supercharged fx35 i wasnt impressed at all
On with the install....
The heat exchanger system is intricate, with an auxiliary coolant reservoir complete with a pressurized cap, electric pump on the left front clip and a substantial heat exchanger mounted in front of radiator. We will be spend quite a bit of time making sure plumbing looks as close to factory as possilbe and use OE fasteners wherever possible.
Next step is the install of the cold air intake system with K&N filter
The supercharged engine will run 1 rangeg colder NGK PLFR6A/11 plugs (sorry for the poor focus :dunno:)
Heat exchanger coolant pump mounts on right front pumper clip
And the heat exchanger (intercooler) coolant resevoir finds a home nestled next to the powersteering pump
Wiring is coming next...
psmwrx wrote:ive driven a supercharged fx35 i wasnt impressed at all
Having driven the completed project, it's hard to understand how you could feel this way. It is so much faster than original.
The piggy back control unit for engine managment and the additional fuel injector are installed under the glove box. (sorry, no picture of this). Next we move to the exhaust:
The ugle and stock exhaust has to go
To be replaced with a true dual exhaust with crossover x-pipe
The all important SMOG certificate
And we're sad to say, the project is finished. It was a lot of fun and we would love to keep going with more mods. But we'll stop for now...
Tell your customer not to bring it back until it's lowered....
Looks wicked though.
AZhitman wrote:Tell your customer not to bring it back until it's lowered....
Thank you! It's just begging to be dropped and get some big red brakes....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Too bad Stillen didn't paint the heat exchanger black allso, and not just their name.
Yep.
One can of flat black radiator paint will fix that.
AZhitman wrote:Yep.
Agreed! We are doing this now
This is an interesting profile on the owner of this car http://www.beshoffinfiniti.com...d.htm
And a sweet sound clip http://www.youtube.com/watch?v=8fbIC3MdutQ
Modified by Brian@BeshoffInfiniti at 11:04 PM 12/1/2009
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
