Dmnitsadean wrote:meah too...help me understand this sitatution...but when I went to go check how much a valve job cost about, my friend says bout 80 bucks but dunt know exactly wat a valve job is, my friends told me it was juss an alighnment but watever I juss need to rebuild my last valve or something thats what da original owner said well I need help on this too....whats your situation...well dats if you know? wat do you feel rights now wen you drive your car?....DeAn
Your friend is talking about a simple valve adjustment for a hydraulic valvetrain similar to a Honda.
KA24DE's have mechanical setups. You have to re-shim the head in order to adjust the lash.
A real valve job would cost a good amount of money to do; as it requires a number of manhours to complete disassembly and reassembly plus machining of the head components themselves.
If you had bent valves your car wouldn't idle or run smooth at all. The only way for a KA to have bent valves is if it floated a valve or the timing chain jumped. Which case the engine would barely run if the timing was off that much.
Please type out messages like you care... nothing annoys me more than someone who shortens words (dat, u, mah, etc.) and doesn't take the time to properly spell the word. It's an expression of your character, and I personally don't want to sound like an uneducated, illiterate ghetto punk.
