Bent rims causing vibration...and permanent vibration?
LegendRacer
I was driving with a slightly bent rim for a couple months due to no time to take it to repair. And after repairs, the bend was gone, but it still vibrates on high speeds...
the shop guy told me its probably a bad tire then, cause when he threw the rim on the spinner, it spun straight (i saw before and after to prove the difference)
but now i fixed it, and the car still vibrates on the side i put the rim on (passenger rear), when i go over 80KM (50miles) i feel the vibration when i am slightly turning right, and non when i have my wheel to the left (that ensures that the vibration is coming from my right side)
question is, is it true that my tire is causing this? or could it be something mechanical in hte suspension area? becasue i used a bent rim for too long?
Rolling Estonian
Car: 2008 Altima Coupe 2.5
sounds like running on that bent rim has damaged you wheel bearing.That would be my guess.
LegendRacer
thats what i would be guessing too, but do you think the wheel bearing is covered under warrenty? or is it normal wear and tear and not covered under warrenty, but then it is just that one bearing tho...
Rolling Estonian
well if the dealership found out the cause it probably wouldn't.
but if you go in and play alittle dumb, say it just started vibrating a couple days ago it would probably be covered.
you need to get it check out anyway. It would be really bad news if it failed completly while you were driving
LegendRacer
Rolling Estonian
your thread was moved to the wheels and suspension area
LegendRacer
no wonder when i clicked refresh it made a huge fuss... hmm sorry mods!
ADKSaad1387
Car: 2012 Infiniti G37X
2007 Nissan Altima 2.5S Majestic Blue
balance and rotate the tires
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
no need to rotate unless it's that time, but have it balanced. should cure your problem.
Rolling Estonian
I think the "spinner" was the tire balancer.
LegendRacer
sorry newbie, and yea i think the spinner is the balancer haha
and its not the wheel/tire im so concerned about, i drove it with my spare tire (that thin piece of ****) and max speed i could go was 80km on those things, and i did feel the same vibration (but not enough to make sure its the same problem)...if i only i could get a wheel to go 120km on then i can feel it forsure
Rolling Estonian
try putting the wheel in question on a different corner.
I still think it's the wheel bearing
LegendRacer
Rolling Estonian wrote:try putting the wheel in question on a different corner.
unfortunately i think so too.... i wonder how much it cost to replace/fix it if i cant get it done thru warranty...
mzinsmeister
Car: 2008 Nissan Altima Coupe 2.5
where are you feeling the vibration?
LegendRacer
to be exact, the vibration is from the right (90% sure its the rear)and when im traveling 100km / 60miles and when i have my wheel turning slightly to the right i will feel it, the faster and more angle the wheel turned, the louder/stronger vibration. When i am turning left at highspeeds i feel absolutely nothing, only when i am traveling at a angle to the right
mzinsmeister
so on the rear right side of the car.. ok I was wondering because I feel a small vibration on my gas pedal but It really depends on the road Im on or sometimes when I'm turning. I took it to the dealership and they told me the car is fine and that it mostly caused by the wheels since it's a different size which can make the car a ruff ride. Good luck with your issue I hope it all gets worked out, keep us informed
