Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Fri Feb 26, 2010 7:08 am
The guy who swapped my KA in my first 240 did this.It's extremely hard to get new pipe fittings for the rack w/ the same thread pitch SO here's what you do.
First of all if your lines aren't broken and just bent, bend them back and you're done lol.
If not,Take the old line off , remove the threaded end fittings from the line. Take the line to an auto parts store and find some brake line/hard line the same size.
Buy that, it will come with fittings that don't thread in so throw those out.Cut the new line and bend it to fit.You'll need a brake line/ pipe flaring tool, just make sure you insert the old threaded pipe couplers on to your new line before you flare them out.Then you're ready to install
