Bent pinch weld jack tabs
SpdElemts
I went to look at a 93 240 hatchback and i was inspecting the jack tabs and found that two were bent and one was bent flat. Is this a major issue? Can this be fixed by a body shop?
Thanks
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
if its just wear the car was supposed to be jacked up, dont wory about it, its not worth it to fix, mine were bent when i got my car.
-Dan
gabossie
Car: Your mom
I think they all bend over time. I know mine are bent, and were when I bought it. Not a problem.
Ceptos
Car: 95 240sx
yeah thats probably from someone using shop jack (or any other jack that did not come with the car) to lift up the car, the tab rests on the jack and gets bent. nothing to worry about.
USDMSTALKER
Car: MY CAR
your suppose to jack the car up on the rear end or below the stearing rack any way
