lylasohc »
https://forums.nicoclub.com/lylasohc-u173471.html
Thu May 10, 2012 12:41 pm
So I found I have a slightly bent part of my front subframe on my s13. I was changing my front right ball joint and notice the arm wouldn't come out that easily. and what do u know, the part that holds the arm is bent round the bolt. Its not that bad but I've been getting wheel shake at high speeds. My last post explains more bout the shake. So i was wondering how i can bend it back in place so it won't be rubbing on the metal. Or i should get a whole new frame. My trac arm is fine. Con Arm is fine. Its just where the bolt holds the arm is bent. I'll post a pic later. Any help be great. Thanks
