Dj Hentai »
https://forums.nicoclub.com/dj-hentai-u149857.html
Fri Jan 08, 2010 6:35 am
The further you lower the truck, the less angle your driveshaft has which in turn moves it closer and closer to the transmission, and if you used blocks to lower it, and they aren't angled blocks, the driveshaft will contact the seal inside the tail end of the trans and rip it allowing trans fluid to leak out.
Also, it's alot more work, but if you just take the guts out of the pathfinder axle and swap them and the brake hardware into your regular axle housing, you won't have to worry about spacing.
