Bent CAS disc
sleepsilvia
Car: 95' 240SX
ok, i got my SR running last week since almost a year, but its still having the same problem as it did before. the car idles fine, but sometimes it sounds like its skipping. when i'm driving, it jumps and bucks until around 3000rpm's, then its fine. today i was checking some things out and saw the gasket around the plastic cover on the CAS was hanging out and leaking oil. so i took it off to see if i could get the gasket back on and discovered this:
sorry for the crappy pic, but the round metal piece is bent only in that area. i'm trying to find another CAS at the moment to test it out, but do you guys think that would be why its running so bad?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Yes.
sleepsilvia
Car: 95' 240SX
haha, thats all i needed to hear. thanks man!
Neil
Car: shooting laser guns
lol wtf.. If only that cas could talk.
I'd like to know what sorts of accidental dumb **** goes on in the engine importing business..
sleepsilvia
Car: 95' 240SX
yea seriously, it makes you think. i bought it from a pretty reputable company (JHOT), but i'm wondering if they actually knew of this.
jwlong1379
Car: 240sx
when i got my sr it was blown... did a rebuild on it and it wouldnt start found out it was because of CAS disk was bent. mine was way worse than that.
replace that and you will be good to go
bruinbear714
I wouldn't be surprised if that bent CAS disc was the cause of the engine blowing up.
You can fix it and use it temporarily by flattening out the disc CAREFULLY with a pair of pliers, but I wouldn't use it in the long term. A slight deformity on the disc could mean the difference between an extra degree of timing or your motor blowing up
sleepsilvia
Car: 95' 240SX
bruinbear714 wrote:I wouldn't be surprised if that bent CAS disc was the cause of the engine blowing up.
i'm gonna wait until i get another CAS. i just got my car running for the first time in 10 months, i'm not risking anything. way too risky if you ask me....
unknowns13
yea a bent cas disk is bad i had the same problem, on the way back home to arizona from kali, wouldnt drive past 2500 rpms, every one was saying it was a maf but found out to be the cas. but good luck with it
sleepsilvia
Car: 95' 240SX
got the new one today and installed it, its running strong now! thanks for the input guys!
