:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Sep 16, 2004 7:45 am
Insanity...enough with the intake manifold thing...it's not the answer to every KA power question.
I've shown you that the peak HP and TQ can be moved around with cams...in turbo applications, and N/A.
I've used my dyno charts (you seem to think my KA is "magical", so I've had non-typical results)...charts from KA-T.org, etc...
Well, here's one more (this old KA was kinda weak, so the numbers are a little lower than typical):
From Alex Chang (mav1178) over on FA...
"Green is stock.
Red is AEM intake, Hotshot header, 5Zigen Fireball exhaust, JWT ECU, UR underdrive pulley.
Dark Blue is with addition of JWT cams set to factory cam timing..."
See how stock the HP peak was at ~5800...
Then he made the engine breathe better with I/H/E, and added the ECU to optimize things, and the pulley to reduce drag...and the HP peak is still at ~5800.
Then come the cams...and the HP peak is now at ~6200.
Now, we can eliminate ALL the other mods as possible things that changed the HP peak. Here, it is undoubtedly the cams that made this change.
We've agreed that an intake manifold would be a good KA modification, but it's not the damn end-all, be-all of KA tuning...!
BadMojo -
The ECU will add a few RWHP, maybe 5-6...but it makes the car much quicker feeling and has much better response as compared to stock.
Plus, for drag racing, the higher redline makes it so that you can cross the line at ~91-92mph bouncing off the rev limiter in 3rd, rather than having to shift to 4th and lose time.
Is it worth $600...I don't think so. For $350-400, absolutely. Try to find a used one, they sell in that range.
- Brian
