lucky03602 »
https://forums.nicoclub.com/lucky03602-u20182.html
Tue Apr 14, 2009 2:06 pm
i have an off the wall kind of question.
if you upgrade your intake, then the "bottleneck" happens to be your exhaust, if you increase your intake and exhaust, then the bottleneck is your fuel (correct me if im wrong, heard it a long time ago.)
so by increasing your intake (size and cone?) then you have more air going into your engine, and then if you increase your exhaust (mani, cat back) you also increase how fast the exhaust leaves your engine? (work with me haha) then increasing your fuel will ultimatly result in no more bottleneck idea right?
if you did all that, intake, lets say venom injectors (10% more fuel flow), mani and catback, after all that would an upgraded maf make more sense?
obviously this is based on an n/a appilcation. AND i could be way off on my thinking, and its only something brewed off the top of my head.
and lets just say this is all true, imo sounds like too much money to spend on a simple item for n/a
