I have searched this forum and others and never saw any information on this topic. Since I have ran into the problem of having the wrong spring in my wastegate I wanted a way to bench test the wastegate before ever installing it on my car. I really think that bench testing would take a lot of the guess work out of troubleshooting wastegate failing to open or open at a certain psi. So I have copied an email that I sent to Tial so those of you that want to test their wastegates prior to installation would know how to do it.
----- Original Message ----- To:
[email protected] Sent: Monday, January 24, 2005 2:40 PMSubject: Testing Wastegate
The wastegate that I purchased had the wrong spring installed Big Blue 14.5psi . My application requires the small green spring rated at 7.5psi. I have replaced the spring and wanted to know the proper way to test your wastegate. I tried using a tool that applied controled pressure to the air control side port but the valve never opened. I am wondering if something else is wrong.
Thanks for your help.
[email protected] To: RobertRobert, The unit when bench testing the pressure to open the unit will be higher because there is no exhaust pressure against the valve. The valve should begin to open around 8psi. tech
