Belts
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
fresco216
Car: 2004 Infinity FX35
Does any one know of a link that will give me the directions on how to change the Serpentine Belt on an 04 FX35?
Thanks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to Nico!
We have an article here on replacing the belts on a G. Since they have the same engine they also share the same belt setup on the earlier models.
The key difference is that you will need to remove the lower splash shield to access the tensioners with ease.
Replacing Drive Belts
It is a pretty straight forward procedure, a quick word of advise it to make sure that your lined up on every rib of every pulley before starting. I have seen many people start the car and be off on rib on a pulley and destroy a brand new belt in seconds.
Good Luck
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
