JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Thu Sep 26, 2002 4:32 am
Unless they are cracked beyond belief, you should be able to just tighten them. There are adjusting screws that you can turn to take up slack in the belt. Before you do that, press on each belt and see how loose it is. They should be tight, but not OVERLY tight. Basically, about 1/2 movement as you push. Belts are cheap tho, and replacing them makes sure they dont break on you while you are driving.
EDIT
And no, when you start your car, both belts are turning, either could still be squealing.
