evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Sep 20, 2006 4:58 am
the power steering can be tricky, you might have to rotate the pulley to align the access hole in the pulley to lign up with the pivot bolt, also take the fan shroud off first thing, makes the whole process much easier, you'll need to get to both the top and bottom to replace all the belts
