180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Apr 11, 2004 9:04 am
check the belts for cracks and what not. If they're worn down, they're going to slip. If you over tighten, they'll squeak too. After you've tightened down your belts, push on the belt between some of the pulleys. It should flex a little bit, not too much but still flex a bit. The dressing should help quiet down the belts, but it might just be masking a bigger problem if your belts are old and worn.
