my
240kid wrote:start the car and look at the water pump to make sure its spinning
im with him, the fan should be spinning. How tight do you think is tight? you should be able to apply moderate pressure to the belt imbetween the the fan pulley and PS pulley, and it should only deflect about 1/3 of an inch! also if the belt is too long you might not be able to adjust it far enough, check with the old belt to make sure its the proper length/size. The parts guy may have given you a bogus one.
C1rca wrote:ive looked and everything seems to be in the right place belts on i had it really tight then loosend it and it still did the same thing but the water pump isnt on that belt i dont think
look at the fan pulley, then follow it to the engine block, where it bolts to the engine is a housing. Under that housing is the water pump. 2 cooling devices powered by the same pulley convienient eh? can also mean the two things cooling your engine arent running at all!
