belts and pulleys
raging panda
Car: s13 coupe
If you got an underdrive pulley for the crank, do you need to get new belts or just tighten them more? I was looking at the ASP and it seems tempting for 100 or so bucks.
unleash the beast
Car: SPEED!!!
i'm fairly sure that new belts are needed. I just ordered the pulley and if any body can let me know what part# belts I will to install the ASP pulley
bruinbear714
The belt #'s are on ASP's website, and also on 240sx.org
You will need the alternator belt and the power steering belt. The a/c belt is the same size.
unleash the beast
Car: SPEED!!!
thanks alot!!
TommyyJ
i just got done tonite installing my asp pulley on my 98....only one problem, i retained the factory belt for the water pump and power steering pump...my gates belt # ko30384 would not got on there...the factory nissan belt fit like a charm...i dont get it....
raging panda
Car: s13 coupe
This is exactly why I thought I would ask. Maybe it would be wise to try your original belts and if they dont fit, then get the recommended ones? I think thats worth a try.
backdoc2be
Car: Cycling, hiking, photograpy, my 240sx
I just order some unorthodox racing pulleys from Adam ext 138, and he beat everybody by $50! This was a complete set, not just the crank pulley. $359.99 and he said that he would do it for others on the list if you are interested.
bruinbear714
backdoc2be wrote:I just order some unorthodox racing pulleys from Adam ext 138, and he beat everybody by $50! This was a complete set, not just the crank pulley. $359.99 and he said that he would do it for others on the list if you are interested.
That's a decent price, but I don't know if I would spend $360 on a set of pulley. I would save up for a turbo kit, which is what I"m doing now. :)
pitbull_240
Car: American Pit Bull Terriers, newly acquired '95 240, PS2, Martial Arts, Fishing
backdoc2be:
This Adam guy, does he work directly for U/R??? I am interested in getting some of those pulleys as well. I plan on keeping the '95 I have NA for at least a year. (Buying another KA to build from the ground up for my Turbo, the way I see it, I will end up with 2 - 240's, 2 - KA's, & 1 - SR before its all done with LOL.....) If Adam doesn't work for U/R, what company does he work for??? I would like to get with him.
Thanks!
Dattebayo
i dont know if i would buy a crank pulley cause of the harmonic balancer. Everything else fine. but i believe in letting an engine go the distance without destroying the crank seal and specs.
TrunkMonkey
Car: 2000 Lincoln Navigator
2BN_S13 wrote:i dont know if i would buy a crank pulley cause of the harmonic balancer. Everything else fine. but i believe in letting an engine go the distance without destroying the crank seal and specs.
the KA doesn't have a harmonic balancer. it has a harmonic dampner. removing it will not harm the engine.
-demetrius
special_K
What is the difference between a harmonic balancer and a harmonic dampner? If the stock crank pully does serve as a harmonic dampner then i would think that removing it would cause harm to the engine. Correct me if im wrong but, I thought that the KA was a very rough engine to begin with because it doesnt have any balancing shafts....
TrunkMonkey
special_K wrote:What is the difference between a harmonic balancer and a harmonic dampner? If the stock crank pully does serve as a harmonic dampner then i would think that removing it would cause harm to the engine. Correct me if im wrong but, I thought that the KA was a very rough engine to begin with because it doesnt have any balancing shafts....
the KA's harmonic dampner is there to absorb the initial shock of the a/c clutch kicking in. since i had no power steering or a/c on my KA, i removed it. i had no problems whatsoever.
the main reasons the KA is runs rough is because of it's long stroke and half counterweighted crankshaft.
-demetrius
keepingthe240
He works for stillon....he only has a few good deals. Look about and you'll see some better prices out there.
pitbull_240 wrote:backdoc2be:
Thanks!
_dk
Car: 1991 RB20DET coupe
[quote=" bruinbear714 That's a decent price, but I don't know if I would spend $360 on a set of pulley. I would save up for a turbo kit, which is what I"m doing now. [/quote]if you check out the dyno sheets they have posted on the UR site, it looks like they're a pretty good addition to a turbocharged car too...
http://www.unorthodoxracing.com/dyno.html
but i can see why you'd wanna get the turbo done first. :)
