Belt tensioning specs...
LongBeachQ45
Car: 1997 Q45/Cima Hybrid
Ok, I successfully replaced my chain guides, but am getting a slight squeel when I first start my engine. I am pretty sure it has to do with the tension on the belts, but the manual was a bit vague. Yes, the bolts holding on the pulleys are torqued to spec, but the manual shows a diagram with tension numbers and no explanation on getting them to their standard. Anyone know how to do this, or at least a good eyeballing it rule of thumb? Thanks in advance.
superuber
I do have a tool to measure belt tension.I'm not sure if Infiniti has a specific tool for the job, I'm sure others know.If you are getting a noise on start up coming from the belts, they are probably to loose. It's usually the alt. belt. If you do not have a tensiontool try tightening that belt. But be careful not to overtighten! The belts will loosen anyway due to stretching.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i like to be able to tug on them and have about 1/4 inch of play.... Tight, but not CRANKED on there.
Raxephon
Car: '04 RX8...for the moment...
You need one of these:
Raxephon
Or one of these.
Otherwise its a "best guess" situation.
LongBeachQ45
elwesso wrote:i like to be able to tug on them and have about 1/4 inch of play.... Tight, but not CRANKED on there.
Thanks Wes, your technique helped me rid my engine bay of it's banshees.
elwesso
2007 BMW M Coupe
