belt tensioner question
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
Ok, I gots a lil bit differant setup then most of u guys since im fwd. my PS pump is where the alt should be on a rwd setup (intake side). The problem is that my pulsar had AC, but I got rid of it to make room for turbo pipeing. I actully moved my alt down, where the rwd PS pump would normaly go.
I am haveing nissan look for the brackets to correctly move my alt down. but in case they cant find them... anyone have the brackets for the stuff on the exuast side of the motor?
When i took off the rwd alt, i noted that the bracket mounted almsot the same as my ps pump. i only had to change the tensioner to fit it. but i dont have anything to tighten my alt (rwd PS). SO, if anyone could show any pics of the bracket or knows what i mean and could help me out, that would be MUCH apprieated.
Thx all for looking.
float_6969
Pics would help, I'm a bit confused.
