tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Sat Mar 08, 2008 11:34 pm
I actually just replaced a tensioner pulley for the AC since it threw a belt and popped the Alternator belt off at the same time.
Both tensioner pulleys have the same setup.
They don't have lock washers, they just need to be tightened down enough as to not come loose.
Loosen the tensioner, remove the belt, and spin it freely. You are checking to make sure the bearings are not out. My guess is that they were just not correctly pieced together when reinstalled(if that is what happened).
Sorry i didnt take any pics of the process, as it is so easy to get to I figured it wouldn't be necessary really.
Take a look at the service manuals that are posted in the sticky though, i bet you can find a pic of how the pulley should all go together.
