ArmedAviator »
https://forums.nicoclub.com/armedaviator-u262955.html
Thu Apr 21, 2016 6:48 pm
Well a belt is a belt. I ordered a Gates from Amazon for $25. As far as the other stuff goes, I will want to get the old belt off and see how the bearings feel on the idler pulleys and tensioner pulley.
The tensioner itself is extremely stiff. Normally, I can manipulate these tensioners easy with a regular 3/8" ratchet. The one in my M37 takes more strength than I am comfortable giving it before I brake the tensioner, the ratchet, or my fingers (if and when it finally does break lose). Is this normal for this car? I sprayed some PB Blaster on the backside of it and it atleast wiggles a bit with the same amount of force I've been giving it but I still can't get it off.
Is this normal or is there an issue with my tensioner?
