belt>?
Another240Bandwagoner
Quick question prolly stupid but, i just did a twin cam swap in my piggy and i dont have the power steering lines from the DE but i need the car to run pretty soon...so what size belt should i use for the waterpump to turn? thanks.
3dKa24
Car: 2000 altima SE
I don't have powersteering either. I just left the pump there so I could use it as a tensioner... My pump is probably burned up but doesn't matter because I"m powersteering less... Don't even know how you'd be able to put a belt on your crank pulley and water pump. Maybe remove water pump and slide it back into palce with belt on?? Use a string to measure the length of the belt you need and then go to the parts store and start measuring.
Poking fun at the double postSorry
240marcuSX
Car: E34 525i
E46 M3
wait, im not sure that I understand your problem...
If your running a DE, you need the lines from a DE, that has nothing to do with belts...
