Belt Sizes
charlotte240
OK, I know the gates sizes for belts. K050370 Alt. K040345 PS & AC.
Does anyone know the sizes for Dayco belts? Pep Boys only sells dayco and there isn't an autozone for miles.
SmithSR
Car: 240sx
Should be a crossover book in most auto parts stores. Keep up the search. Call around if you must.
It's odd that pep boys has no crossover book...maybe you had a run in with a guy who didn't want to help...
quiksilvia
Car: 95 s14 se
do u need the belts right now or are u stocking up, heavy throttle has them.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
14mm x 890mm18mm x 955mm
Those are the dimensions of the two belts that I got from heavy throttle. You don't need part numbers to find belts. Most belts are universal depending on size etc. Just tell them the size above, and they should be able to find something.
charlotte240
I'm just stocking up. I just need to send my harness off and I'll have the swap ready to start. Other than hoses/belts.
Thanks ItzGenX, I'll try that because pepboys had no idea what I was talking about when I mentioned K040345.
