Belt sizes '91 Q45
timatt
Hi all:
I haven't posted in awhile. I have a '91 Q45 which needs a water pump replacement. While I'm in there I want to replace all four belts. Can someone provide the belt size/specification/part number for each of the 4 belts?
ThanksTim
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Tim
I would recommend getting the set from Joe... I have had BAD experiences with aftermarket belts.... When i helped another NICO member do the guides, we replace the belts and the AC belt was about an inch too short, so it made it a real hassle to get it on....
likewise, i was also replacing the blts on my Q and the water pump belt was an inch too long....wouldnt tension down....
however, im not gonna leave you hangin, so heres the scoop:
Alternator- 6 rib, 960mm Waterpump/PS- 4 rib, 1285mmAC compressor- 4 rib, 945mm
1990Q45'r
Car: 1990 Q45
Gates Belts are excellent. Available at NAPA.
