KimberlyS13 »
https://forums.nicoclub.com/kimberlys13-u79941.html
Thu May 01, 2008 12:42 pm
I'd like to thank anyone before hand that took the time to read this post and offer advice/suggestions/help!
-Car Specs-1990 240sx KA24DE motor
Symptoms:
1.) Sometimes when starting the car, or when shifting/downshifting, the car would make a loud squeeling/screeching sound. This sound lasts about 2-4 seconds. It doesnt feel like a grinding of gears when shifting or sound like it, but I'm not certain.
2.) The screeching noise explained above is slowly happening more frequently. Maybe 1-2 times a drive.
3.) My first thought was a lose belt, but it happens sometimes on a shift/downshift.
4.) Here is todays big problem: It made the slight squeel for 1-2 seconds, so I started to shift, slowly accelerate and try to analyze what was causing this. During this time I noticed a power loss, a feeling like a fuel cut off and the motor was choking to continue to accelerate. I also noticed an odd faint noise; I would say it was a noise created by a repeated motion.
5.) I pulled the car over, and thought maybe the motor was jerking around so rough that the radiator fan was nicking something inside and burning the plastic fan because at thiss time i smelled a horrible rubber/plastic burning.
6.) The noise stopped, the smell went away, and I needed to get home fast. 1/2 away home the same thing happened again where i lost power, heard a repeated soft sound, and smelled the horrible smell. The idle slightly more rough than normal.
7.) Finally when I got home, I popped the hood again and tried to find the burning smell. The radiator fan looked ok. There was a light smoke coming off of the throttle body. This smoke lasted maybe 30-60 seconds. I cant say it came right off the throttle body, or something around/under it.
SO! If you bothered to read all this I want to say thanks again:) And this is a shot in the dark, but my wild guess is:
A belt is lose/weak/worn. Maybe the pulley is spinning inside the belt, causing the power loss, followed by the burning smell of the belt. I dunno, i'm lost
Thanks for advice guys!
