Belt Life ?
mfn1194
I just had the engine drive belts replaced on '03 G35. The dealer said they were cracked and dried out. Said better to replace now, then when it breaks on the highway. Car is 7/02 build date, with 43K miles. Is this premature wear ?? They also changed brake fluid, he said it was very dark.
I though belts go to 100K ? or can they get "weather beaten" regardless of mileage.
Q45tech
My 17 years experince with Infiniti [in the South] shows that by 30-40k the belts are cracked and should be replaced to avoid future failure.
Cracking depends on local ozone levels, as that attacks the rubber.
Important that the tension is measured and set correctly with a gauge.
Too much tension can wear the bearings faster in alternator and other components..........idler pullies.
Few rubber components [hoses, belts, isolators, etc] last without proper antioxidant treatment frequently.
G_whizz
Car: 2010 G37 Coupe Sport
Welcome to Nico
Tahoemofo
Car: 2004 Infiniti G35 Coupe
If you don't mind my asking - what did the belt replacement cost? I think I need to have mine replaced as well. Just wondering what to expect.
thintzen
i had my belts replaced on my 03 g. the dealer charged me 180 with install.
infinititech1
they usually start cracking about 30k or so
Fenvy
Car: 2005 350Z Base 6MT
Q45tech wrote:Few rubber components [hoses, belts, isolators, etc] last without proper antioxidant treatment frequently.
what do you recommend from kragen/autozone?
Road Ruler
Car: G35 sedan prem
30K ?????
3 times now at every 100K I replaced the timing belt and all accessory belts on our 93 Nissan Quest . The old belts looked good but I changed them all as PM.
Note.... K meaning kilometers
