Belt keeps getting loose after tightening it.
Euroz33
My belt keeps getting loose and my engine over heats, my friend helps me out to tighten by loosening the bolt a little then getting a tire iron and pushing the pulley up and then i put the bolt on tight and it tightens up my belt, well it keeps getting loose! I searched but i couldnt find a answer... So im asking for help!
& I put a ÆM Intake, well theres a hose that's not being used and has no plug in for the intake and i was wondering if its something i need or just dont need.Heres a picture its between the tube and intake.
& I was going to put stainless headers, but decided not to , So im wondering do i need the heat shield back or not??
& my cluster had no lights so i bought some and put them in and they aren't lighting up.. Should i just buy a new cluster or what/?
Modified by Euroz33 at 7:28 PM 4/7/2010
Modified by Euroz33 at 8:03 PM 4/7/2010
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
you are definitely missing a part of your tensioner. There should be a bolt that pulls the unit tight and then another bolt that goes in the side that locks it in place. You shouldn't even need a pry bar.that's old school v belt way to do it.
Euroz33
Yeah i see what your talking about , do you know what the bolt size is??
Modified by Euroz33 at 8:36 PM 4/7/2010
