belt adjustment points on G35??
andrewjetmitchell
Car: '05 G35
Its a 04'/G35 sedan..Replacing serpentine belt and cant find the belt adjustment?? I assume Its the Idle arm pully but Ive loosened the front nut and nothing happened. I need the adjustment points for the main belt and air conditioner?? Help!! Jet
G_whizz
Car: 2010 G37 Coupe Sport
Hey Jet ...welcome to NICO!!
I will have someone answer this question for you shortly!
infinititech1
there is 2 belts...both are the same way
loosen 14 on the idler pulley and then under both of those is a 12mm gold bolt/adjuster...loosen this to remove belts...tighten it to adjust the belts tighter
G_whizz
*poof* Just like magic !! Infinititech to the rescue!LOL
Nice work, Drew!
infinititech1
werd up
infinititech1
oh yeah...don't forget to retighten the 14mm nuts after you adjust the belts
andrewjetmitchell
Car: '05 G35
Thats the ticket...just what I needed. Is that from the online service tech?? Should I buy that, Is It worth it?? Thanks for all of your help. Jet
G_whizz
LOL...I'm sure if ya wanted to pay Infinititech he wouldn't argue!! But the Bossman (AzHitman) might have a problem with it!
All the advice and info. on here is free of charge my friend!
Welcome to NICO!! Now spread the word
infinititech1
i'm secretly paid under the table
lol jk
